buckmeister2 »
https://forums.nicoclub.com/buckmeister2-u224114.html
Sun Aug 18, 2013 3:57 pm
hi, I am late to this, but it might help someone else. You are asking about a "1 size up" change, and that almost never causes any issues on any vehicle. the 255's are just .7" taller, so you are looking at just about 2% increase in height, which means speedo will be off by 2mph at 100mph. Odometer will be show 2 miles less than actual travel for every 100 miles...in other words, negligible change. The tires fit on the same size rims.
The T/A is not a great tire, and doubt if it is as good as the Geo-Trac. The best deal you probably get on a tire for your vehicle is the Firestone Destination LE, which is an improved Destination model, and is the highest rated tire in almost any comprehensive survey.
