Infiniti4infiniti »
https://forums.nicoclub.com/infiniti4infiniti-u266156.html
Fri Dec 16, 2016 2:04 pm
9.5" wide wheels just like the post says.... I am not lowered at all. my setup fills the wheel well perfectly. I only regret not going with a +44 of set versus the +42 I went with. 2mm isn't a huge deal. My previous set up I had 20x9 Verde wheels on 255/40's and had a bit of sidewall roll. wheels sucked!!! very hard to balance. finally got them balanced at the dealership (road force) Discount tire tried 16 times (no BS), I ended up getting a better quality wheel (MRR design wheels) I am still on the 255's that were on the 20x9's. they are a tad strected in the side wall ( same as the 245's on the 19x9's the as g37 coupe rears have) the stretch helped stiffen up the tires but now I have no rim protection. I'll be going to a 265/40 next. my 20x9's were a +38 offset to get the wheels flush with the fenders but that affected the scrub radius (look it up) which did affect the handling. I would recommend a 20x9.5 (alot of sites ay it wont fit but you could actually got with a 20x10 with a +45 offset)...A 20x9.5 wheel with an offset between 42-45 will keep your scrub radius the same and put the outside of the wheels flush with the fenders. the 255/40 tires I have on there now are a 28.1" diamenter (.5" LARGER THAN STOCK WHICH FILLS THE WHEEL WELL) I am not planning on lowering but if I did I would ONLY DO COILOVERS) dont waste time or money lowering with springs...it's cheap and will mess up a lot of s***...I have learned my lesson in the past....
