Anyone Running 19 inch or Larger Wheels on their 05 Q45?
05CobraQ45
I'm currently running 245/40/18's on 05 Q. Thinking about moving to 19 or 20's. If anyone is running either of these sizes please let me know what size tires you are running and if there are any performance or suspension issues due to the larger wheel? Also, did you stick with the +45 stock offset? Did the change in size require any fitment modifications away from stock?
Thanks
ps-im not looking to spend a fortune :chuckle:
Ikon_1911
Car: 1995 300ZX 2+2 NA
What was the outcome?
ajduck65
Car: 2003 Infiniti Q45
I have an 03 Q. I'm running 20x9s with 245/35/20s up front and 20x10s with 275/30/20s on the rear. No modifications or change in fitment. I have 4 piston slotted Brembo on so I had to go big. Hope this helps.
gemman69
Car: 02 Q45 & 05 Xterra SE
ajduck65 wrote:I have an 03 Q. I'm running 20x9s with 245/35/20s up front and 20x10s with 275/30/20s on the rear. No modifications or change in fitment. I have 4 piston slotted Brembo on so I had to go big. Hope this helps.
Did you do a big brake kit? I've toyed with spacing out stock caliper with home built brackets and using almost 1.5" bigger rotors that all fits within stock 18" wheels.
marksport
18" wheels should still clear the brembo as well as most other 14" brakes, mostly is watch for the wheel inner spoke clearance. I've run 245/35/20 all around as well as 245/40/19 fronts and 275/35/19 rears no problem, tho I would rather run 255/35/20 for speedo accuracy.
