Anyone replaced door glass?
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Had my PS door window (not quarter window) broken out last week to steal my friend's bag out of the floor. I was lucky enough to find a guy in town that had an entire door, with the right tint, that I now have.
The problem is, I don't really see how this new glass is going to back in. I got both doors pulled apart last night, cleaned up the broken glass, and started looking at both to figure out a gameplan, and ran out of time.
The 2 bolts for the bottom of the window are a given. However, for the 2 side guide rails, the bolts are facing the wrong direction. I don't see how I'm going to get them on. Furthermore, I don't even see how the black piece thats on the oustside of the window as a guide is going to come off, let alone, how its going to get back on. Turning it seems to do nothing, and I don't want to break it. You can't even get to the back of it.
Any tips or guides that I didn't find would be appreciated. The FSM has procedures for all the other glass, except the doors. I did find this guide, but I'm lost without the pictures: http://www.twinturbo.net/net/viewmsg.as ... id=1001642
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Afraid I can't be of much help, but here's a little tutorial I had bookmarked on how to remove the upper slider/runner from the pillar:
http://www.pexcom.com/images/Rattling-Window.pdf
At least it has pictures! lol
ThisIsSparTTa
Yea, I'm thinking for the 2 guides on the inside of the door, the glass mounts just slide onto...if I can get that runner taken of, then I think I will be set. That PDF looks awesome, I will be using it tonight.
kamikazeeeee
Car: z32
its a pain in the a** just take your time and be careful mainly you going to have a problem pulling the glass of the slides level because if you don't it will keep on getting stuck
ThisIsSparTTa
I have the glass in right now, about to adjust the height with the stoppers. My biggest idiot moment was forgetting to take the 2 broken guides off the rails. Had to pull glass back out. Otherwise, lined up the mirror part first, then finagled the rear of the door until it got down in there. It took a little of shifting the glass and turning it a bit, but wasn't horrible getting all 3 guides to line up. I'm stoked at how this has gone
ThisIsSparTTa
This is what victory looks like : http://imgur.com/1dpwgOB
t.mcginley.jr
1966 Ford Mustang
ThisIsSparTTa wrote:This is what victory looks like : <a class="vglnk" title="Link added by VigLink" target="_blank" rel="nofollow" href="http://imgur.com/1dpwgOB"><span>http</s ... </span></a>
Awesome!!! You should've taken pictures during the install and made a write-up haha glad it all worked out
ThisIsSparTTa
I'm terrible at having the patience to document things. I just want to go and get it done. With a second set of hands, it could probably happen.
For future reference, the steps are:
1) Remove door panel. Plenty of guides out there on how to do this.
2) For door with broken glass, if you remove the speaker enclosure, you can actually get your hand and arm down in there, almost to the end. Fish out as much broken glass as possible, or it will forever be pouring out the bottom.
3) I had an entire extra door that I needed to get the glass out of. After removing its door panel, I stood it upright, hooked my door's motor control up to it, and used it to lower the window all the way down.
4) On both doors: remove the exterior B-Pillar trim by pulling the weatherstripping off, you need to pull it off to the side of the door. There will be 4 plastic pins holding it in place to remove. It should pop right up with these removed. This guide was helpful: http://www.pexcom.com/images/Rattling-Window.pdf . Also, there are 2 stoppers at the top of the door to stop the glass from going too high, remove 10mm bolts. There is also a plastic pin near where the b-pillar trim was, I think supports the window in some cases. This needs to come out.
5) On donor door, glass should now be able to slide right out. Clean up, etc.
6) On broken glass door, remove 3x guides (not the rails), two on the inside of the door, and one on the b-pillar. Lower window motor all the way down. Remove 2x 10mm nuts holding old glass to power window rail.
7) Take glass, start by lining it up in groove made by weather stripping at side view mirror. Then work rear approximately into place. Shift and turn glass until it starts to line up with the guides. I found the guide nearest the side view mirror easiest to get to initially line up, then the one towards the rear, then the b-pillar.
8) Carefully lower glass down until it meets up with power window moving rail. Attach 2x 10mm nuts, don't overtighten.
9) Put 2x window stoppers back into place. Set to max height initially. Roll window up. Close door, adjust window, open door, etc until you get the window to a good maximum height to mate up with weather stripping on car. Move the stoppers down to match up with that position.
10) Put door trim back on.
11) High five yourself.
