Anyone replaced bushings on rear LCA?
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Yeah, I looked around and couldn't find anyone who did. Anyways I'm talking about these bushings: (borrowed pic from 94_240sx) These are S13 LCA btw
With the Energy Suspension ones
I'm gathering info. and parts at the moment so I can have everything before I dig into it.I'm doing all four ball joints along with the bushings on the front and rear control arms. Found info for the fronts but not rears. Thanks.
hilux30
Car: 2007 Tacoma 4x4
you need a press, or take them to a shop to press out the old and press in the new
Bumnah
Car: 1992 240SX, black. Bone stock.
The bushings are like any other bushings. Cut/burn out the rubber. Cut the sleeve. Replace with the poly pieces.
SPL sells spherical bearings as replacements as well (rear lca's).
maj Andres
While we're on the subject, is it necessary to drop the subframe in order to replace the differential bushings? or will dropping the diff be enough?
hilux30
Bumnah wrote:The bushings are like any other bushings. Cut/burn out the rubber. Cut the sleeve. Replace with the poly pieces.
burning the old bushings is fine, but cutting the sleeve will most likely damage the bushing housing, the press is MUCH quicker and easier. Shops should charge little for this work, as long as you take the arms off. As far as the diff. bushings, subframe does not need lowering, the bushings are on the diff (that needs to come down)..... unless you are talking about the sub-frame mounts
rico05
Car: 1992 RMS13 w/ CA18DET
Make sure and use the assembly lube that is supplied liberally. It was a total pain in the a$$ when I did mine. We used a 10,000lb press and it was still a nightmare.
maj Andres
hilux30 wrote:burning the old bushings is fine, but cutting the sleeve will most likely damage the bushing housing, the press is MUCH quicker and easier. Shops should charge little for this work, as long as you take the arms off. As far as the diff. bushings, subframe does not need lowering, the bushings are on the diff (that needs to come down)..... unless you are talking about the sub-frame mounts
Ah, so glad I don't gotta drop the subframe for the diff bushings.
iLLusive240^
Car: Redtop S14 238 whp :D
we blowtorched wedged and cut mine out it was s***ty but we used a vice to get them in. it was tricky but when we got used to doing it it was pretty cake.
