cr4west »
https://forums.nicoclub.com/cr4west-u145518.html
Sat Feb 02, 2013 1:30 pm
I successfully replaced my AC bearing in my '99 QX4. There is an excellent video on youtube showing how it is done, just search "Denso 10PA clutch bearing replacement ".
The replacement bearing is a SKF or NAPA AC2 . Other bearing numbers might be SKF40GS11DS or NSK 40BD219DUK or Nachi 40BGS11G2DS. It cost me $44.
I also purchased a cheap hydraulic press from harbor freight for $60 and a die grinder diamond points set for $9 to remove the 3 shot peen marks holding the bearing in the clutch disk assembly.
Do not remove the entire AC compressor, the bearing and clutch dish come off easily from inside the engine bay! Be carefull when doing this because the spring clip holding the clutch disk in place may fly off and get lost.
Result, no more chattering or squealing.
cr4west on Sun Feb 03, 2013 11:28 am, edited 2 times in total.
