slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Wed Sep 27, 2006 8:25 pm
Just a quick question: did your replacement shims come with a hole in them? I ordered directly from a nissan dealer (MidWay Parts FWIW), and used a dealer micro-fishe to get the correct thickness part numbers. ANyways, some of the shims that came in have a single hole in them, about 1/8-1/4" from the outer edge, and about 1/8" in diameter. Are these to make removal easier, or to ensure the shim seats properly?
Big question is do I have any reason to be concerned about using them on my '92 KA24DE? Shortly after re-shimming my head(perfect gapping now, checked warm) I have a ticking from under the engine bay: I hear it over my exhaust. It's intermittent, but usually it heard when cold or over 3000rpm.
Guides and tensioners were replaced about 2yrs ago, non-OEM FWIW. Should I be checking the right side upper guide or oil pressure?.
(I asked a while back but just wanted a fresh perspective.)
Cheers,Jamie
