Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Mon Jan 15, 2007 6:03 am
I've had test pipes on my Z...didn't have a rattle..but they did crack at the elbow.
The pipes need to ahve a bracket on them, like the stock cats do, to keep them supported and restrain their movement. If you look closely at the 350Z exhust suppoorts...the only ones besides the bracket from the transmission to the cats is found near the rear wheel well on the drivers side. That puts a LOT of weight on the test pipes (the entire Y-pip structure), and if you think of it in terms of leverage, it's even worse. THis can cause a lot of problems, such as stress cracking (like mine) and also not being able to seal them correctly because of the forces involved.
TiTek makes a set from Phase2 I will be ordering soon that ahve a bracket to solve this problem....
Also, re-use the factoty gasket, it's a multi-layer whereas most companies will give you a standard graphite impregnated gasket. the stock one is much better.
-CHet
