I would love to but I dont want to be the Guinea Pigcereal2k wrote:H&R has advertised lowering springs however I'm not quite sure if they are actually available yet. Is anyone planning to lower their vert?
LOL. I hear you on that.bschurr wrote: I would love to but I dont want to be the Guinea Pig
I like the slammed look on other cars. It should not be slammed with the eibach coupe springs once it's done. I've weighed the pros and cons and the only practical pro is that I should be driving within the speed limit now, paying more attention to up coming road conditions LOL. I'll see how speed bumps at the mall go.pwlorraine wrote:I'm not a big fan of the slammed look - definitely don't like cars that look like they'd have a problem with a speed bump. I'd also be concerned about the necessary increase in stiffness to deal with the smaller spring travel and the impact on ride quality - particularly if you have a sport suspension already. But if you live where they've got great roads and you won't break your spine going over a pothole...
Peter
The car would only be "crippled" based on how good the roads are in your area. I had planned on just removing the 2.5 inch wheel gap on the front to even it out with the rear but I'll be getting the rear done too. The other aspect would be how low would it be lowered. It will not be a drastic lowering, so I perceive very few issues (fingers crossed). It would look just a little bit better in my opinionfoxwiz wrote:I can't imagine lowering a g37 at all especially after reading the posts about how careful you have to be so you don't scrape bottom. A 50k car and you want to cripple it? I just purchased one last month and it looks cool as is. Different strokes as they say.
Tim30250 wrote:Yikes, why are so many people so paranoid over a mild drop? Lowering a car 1-1.5" will have almost no negative effects whatsoever. No bottoming out, no camber adjustment needed. I lowered my BMW vert like 8 years ago with Eibach springs and it actually rides even better than it did with the OEM springs, yet it handles a lot better. I does not bottom out on speed bumps, but it will scrape a bit on the front air deflector underneath the car going up steep inclines (like driveways and parking lot entrances) if you don't go in at a good diagonal angle. This is VERY rare, however.
I have been so happy with my lowered BMW all these years that I just ordered a set of Pro-Kit springs for my G37 sedan. I'll put them in sometime after the holiday and I'll post up some reviews.
Bottom line... Don't be scared of the springs. There are many choices from many reputable companies that have been designing springs for years and are custom made for each particular car and purpose. Almost any "street" spring you choose is going to give you enhanced looks and performance without any significant compromise.
Steve, I did another check after 4 months and this was the resultSteveTheTech wrote:Has the rear started to settle on your car?
I have been watching this thread from the beginning and had been waiting to see what would happen with great anticipation. I am a skeptic of the long term durability of aftermarket components vs factory but sometimes they work out, as seen in the M.
I wonder if IPL will offer anything?
Yeah, until there is some after market vert specific camber adjustability I'll live with it for 6 more months or so I'll see what's out there and tested/proven before putting the stock rear springs back.SteveTheTech wrote:I am not an owner just an enthusiast but it looks like that might work or at least give your new tires a fighting chance.
They may have a tread wear rating that exceeds the majority of the others...however your suspension is A typical. Your rear camber is so negative you can see it.
Take this image from 1 meter back and about half a meter higher.
How are you planning on rotating these?
I wonder about rotating them in the reverse condition to counteract any early...although that will not do anything for the camber. The car is riding on the inside 1/4 of the tread face.
39psi , the load rating is 100 which is higher than the stock rating so the weight can be handled.SteveTheTech wrote: There are many possibilities.
What is your tire pressure?
Tires like these are prone to cupping in good conditions, and I will bet you a beer you have early signs before your first rotation.
