Tan.Eskimo91q45 wrote:What interior i need a glove box and the back plastic pices for the seats and the plastic pieces around the front dome lights with the sunroof controls... just a few pieces off hand i need
Where is the controller located? I heard I should keep the fuel pump controller(dont know what this is) as well. And the TB is a non-tcs.Q451990 wrote:You should save the transmission controller... should bring $50-60 at some point, and it's small and easy to store. The throttle body should bring good $$ if it doesn't have TCS.
If you want to unload either of those parts cheap just to be done with it, I'll take them at pull-a-part prices, but you can do better selling them elsewhere if you take a little time with it.
Heath
Didn't realize I did not have my location in my info, I located in Port Richey, Florida. I think the rear sway may be spoken for locally, but if you are interest Im taking offers on everything.GSUjinih wrote:Where are you located at? I am interested in the sway bars and wheels especially if you are not too far away.
The TCU is located in the same location as the ECU, just on the driver's side.IThaJ0kaI wrote:Where is the controller located? I heard I should keep the fuel pump controller(dont know what this is) as well. And the TB is a non-tcs.
Awesome, thanks for the info. I will be sure to keep them, is there anything else that is a common fail point in Qs?Q451990 wrote:The TCU is located in the same location as the ECU, just on the driver's side.IThaJ0kaI wrote:Where is the controller located? I heard I should keep the fuel pump controller(dont know what this is) as well. And the TB is a non-tcs.
Good call on the fuel pump controller. They occasionally bring about $50. It hangs under the rear deck on the passenger side, and is held in place with two bolts that go through the deck. You have to remove the back seat, and finisher with the speaker grilles. The bolts are buried under the sound deadening tar-paper like substance.
Heath
Both of these are broken, the previous owner took horrible care of this car. I will be getting another car soon, Ill let you know if those pieces are ok.Eskimo91q45 wrote:how much will u charge for a glove box!! mine is missing. and need one and the plastics around sunroof and dome light. take some pics i really need one and infiniti is chargeing way too much for a glove box
sadly, just like every one I have ever found it is broken. I am looking for one for my daily G50 also =\Vipstats wrote:What the condition of the drivers rear ashtray? or maybe even the whole door panel? My rear ashtray cover cracked and half of it is missing so its a bad look on the door panel.
