Anyone need 550cc RB20 injectors?
skillzilla
http://cgi.ebay.com/ebaymotors...33554
Series 5 RX-7 injectors, high impedence 550's, direct swap for RB20.
I just bought 6 and theres 10 left, so someone grab another set quick.
Wulfgang
Looks like someone got another 6. Only 4 left.
Lol, that's hilarious! He won't ship to France!!!
goofynick6
Car: 1995 S14.5 RB20DET
I use those same injectors, and MAN do they click...sounds like all your lifters are ticking! Maybe it is how I have them installed and they're just transferring a lot of their noise directly into the rail and head, but they are noisy.
Nick
lyon23
Car: 95 240sx
goofynick6 wrote:I use those same injectors, and MAN do they click...sounds like all your lifters are ticking! Maybe it is how I have them installed and they're just transferring a lot of their noise directly into the rail and head, but they are noisy.
Nick
I got the 460cc and yes they do click very loud..
StricNyne
i got some of those also but i got a rb25 i need a new fuel rail i paid 100 for 6
biglipzit
Car: sr20det S13 RHD 200SX
I just saw these on ebay, What does anyone know about them and will they work on an rb20?
http://cgi.ebay.com/ebaymotors...=WDVW
goofynick6
biglipzit wrote:I just saw these on ebay, What does anyone know about them and will they work on an rb20?
1989-91 RX-7 195500-2010 Saturated 460cc Red Top
That's what I found for that part number, they are high impedence, so they should work just fine; you'll need an SAFC or something else to control them. Then, bolt on a new turbo and goto town with 18psi and some tuning
Nick
biglipzit
lol i got a bigger turbo already and i already go up to 18psi with my stock injectors... Do i really need the safc or will my mines ecu do fine with it?
goofynick6
You're crazy to run 18psi with stock injectors! I'd stop doing that now; they're 270's. You do need an safc or similar device because the ecu, Mine's or not has no idea of what size injectors the car is running if you drop new ones in.
Nick
biglipzit
stock injectors are 370cc's and i run rich the whole way through the rpm range at 18psi but i only do it at track sometimes, I drive 14psi daily.
sileighty89
Car: 89 240sx hatch & 89 coupe
Just ordered some remans for $300.00. I love working for a dealership.
goofynick6
biglipzit wrote:stock injectors are 370cc's and i run rich the whole way through the rpm range at 18psi but i only do it at track sometimes, I drive 14psi daily.
You have an rb20? If so they're 270's.
http://www.meggala.com/injectors.htm
Nick
biglipzit
ok i stand corrected. Hmmmm and i run rich the whole way through 18psi... How is that possible... With stock fuel pressure...
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
No way these are fitting on a rb25 eh? Top feed when I need side feed.... can I convert i am guessing with a new rail?
DETurbine
Car: Nissan S13 RB25
you can make any injector work for any car. With a resistor, bushing rings, etc....if needed. For the fuel rail you can use the RB20's, RB26's, or JGY customs has an aftermarket one as well.
