Jonny 290 »
https://forums.nicoclub.com/jonny-290-u11793.html
Thu Dec 18, 2003 12:55 pm
check the 1.2 or 2.0 mm headgasket department. lower your compression a bit, give yourself a margin of safety.
i'm going with oem head gasket. I want a fuse. It's not guaranteed, but I like the idea of blowing a hole in my headgasket MUCH more than i like the idea of blowing a hole in a piston.
however, if the motor's built, and you're confident, get yourself a beefy gasket and you'll be good to go. I like Fel-Pro.
