nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Wed Nov 12, 2008 10:50 am
you should not need any RTV or gasket sealant on the factory gaskets. They fit inside a groove on your valve cover. If they leak when they are installed that tells you something is faulty.
While the cover is off you could add in some rocker arm stoppers if you are a drifter, but other than that, its easy enough to take the valve cover back off when you need to do something.
