Anyone know where to buy/borrow/rent a vacuum pump?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I am really getting of sick of my EGR problems... The CEL on an otherwise pristine running Q just doesnt seem right..... So I need to continue diagnosis... I do need a vacuum pump, but I dont want to throw down a lot of money on something ill use a couple times nad then do nothing with it...
If I could get one for like $20-30, then Id be happy, but I dont konw..
Does autozone rent them, or some place like that...
DAEDALUS
Car: 1990 Infiniti Q45
A hand vacuum will work, right? Something like this:http://cgi.ebay.com/ws/eBayISA...&rd=1Use it to test check valves and bleed your brakes too if you don't have speedbleeders.
elwesso
2007 BMW M Coupe
Thanks robert! Thats EXACLY what I need..... And to bleed the brakes too!! How GOLDEN!!!!!
DAEDALUS
If you get outbid don't worry. There are a lot out there. I'm sure you can get a good deal if you check around.
elwesso
2007 BMW M Coupe
Yeah I checked around and theyre about $50 new... I dont think ebay will let me down.....
Ill spend more if it will do everyhting, like bleed brakes and all that fun stuff.....
carlos_knology
Car: 1995 Infiniti J30
Wes, that's the exact vacuum pump kit that I have. It works great.
Especially for bleeding the brakes.
Carlos
qship96
Car: 1996 Infiniti Q45
wes,this is a great tool to own,used it to bleed brakes,remove ps and traction control fluids,and other things on the q.
Wes, you're only 18. You're what we call a "late bloomer".
Don't worry, it'll grow.
:D
par2za
hey wes if you want look for a snap-on truck while your driving, and stop him. Youv can pick a really good set for 50 dollars from him they have them stocked on trucks. if your in a hurry to pick one up.
Q451990
http://www.harborfreight.com/c...39522
On sale now for $26.99 at Harbor Freight.
Heath
elwesso
2007 BMW M Coupe
Is that the same one listed on ebay???
Q451990
Just from comparing the pictures, they look the same, but I don't know for sure.
Heath
qship96
was at harbour freight this afternoon,they have 2 versions of the mitivac pump-the 55$ one comes in a case,and is made of metal,the 33$ one looks identical,but is plastic and does not come in the fancy case-I say,unless you will be using this very frequently,the plastic one will do just fine.
