Anyone know where this bolt/bracket goes goes??
Justin35ll
Car: s13 coupe sr20det
I have an extra bolt and bracket and can't seem to find where they go.. off my redtop sr. I don't think they go together.Bolt - It's got a little tapered tip on it, no washer just locking washer
Bracket
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
supports your intake manifold, by your alternator to help support it also
duffman1278
Car: 89 240sx Hatch, the wildcats!
I would just save that bolt, you probably won't even end up using it. I dunno how many times I've ended up with extra bolts when working on cars.
Justin35ll
Duh, how could I have missed that lol.
I'm not sure if I'll be using it yet, I gotta check my block to see if I put that lower bracket bolt back in, if I did then i won't need it, if I didn't then I will need it
edit - alright I got it worked out there were 2 of those tapered bolts and they were used for the side of the alternator bracket. Just had to swap a couple bolts arund I had mixed up and add in the bracket.
Modified by Justin35ll at 12:18 PM 12/13/2008
