RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Tue Feb 06, 2007 5:19 pm
local junk yard is your best bet. it doesn't have to be from 98 either. any sr20 transmission from 91-2002 will work. The only main difference is that in 91-94 the trannys were prone to 5th gear pop out. That issue was fixed in late 94. The newer transmissions, 1999-2002 are hydraulic and require you to switch them over for your cable operation.
So this leaves you many options for transmissions:91-94 sentra se-r/nx20095-97 200sx se-r98-00 sentra se w/pp for lsd91-96 g20t for lsd, standard g20 didn't have lsd.99-02 g20t/sport for lsd, once again standard g20 didn't have lsd.
