Anyone know where I can get a caliper bracket bolt for a 2001 QX4?
Fosty
Car: 2001 Infiniti QX4 2WD
One of mine fell off, and I can't find them for sale.
Autozone had a pair that they said would fit, but I compared it to one of my others and the threading is wrong.
I don't want to take the chance of ordering online and then having the wrong one show up.
I would go to the junkyard, but they only have a 2005 Pathfinder, and I'm not sure if they use the same bolt.
Thanks.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Use the Infinii part numbers you find here...
https://www.infinitipartsdeal.com/parts ... brake.html
...for googling. One of the pin bolts shows discontinued but Amayama has them and I found several on eBay. The screws and the other pin bolt show still available from Infiniti.
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Fosty wrote:
Thu Jan 08, 2026 5:43 pm
If it's just the guide pin bolt that fell off, not the guide pin as well, that is just a common M8 hex head flange bolt. Nissan/Infiniti Pin-Bolt 41136-0W700. At more than $13 per bolt from Infiniti Parts Deal or Nissan Parts Deal, you would be just as well off getting a Grade 10.9 bolt from your local hardware or auto parts store if you can match the length to one you have on-hand. I think it's like 25mm, maybe 20mm, long.
The 2005 PF has a different bolt.
