anyone know what would connect to this? PHOTO inside
rb 90 240
Car: 90 240
My car is running better but its not 100%. I have plugged this off but was thinking if there is a port there, im assuing there was a hose from somewhere that pluged into it. So I was thinking maybe the port on the opposite end might need plugged as well. Just a thought anyone know?
FriedEGs
Car: 1995 SE, Roast Beef!!
the hose with teh blue? or teh tiny hose closer in teh pic?
The hose with teh blue stuff goes to your brake booster, the other one goes to the stock boost gauge from your original skyline cluster.. I used this hole for my boost gauge.
Joe
FriedEGs wrote:the hose with teh blue? or teh tiny hose closer in teh pic?
+1
rb 90 240
Car: 90 240
No not the brake booster hose with the blue rtv. The nipple that is beside it that isnt plugged of and coming out of the back of the intake? That would just be plugged into a stock boost gauge cluster? Just want to be sure I am on the same page here
Joe
yes
BoostFab
Car: S13cp, S13fb, S14z
rb 90 240 wrote:No not the brake booster hose with the blue rtv. The nipple that is beside it that isnt plugged of and coming out of the back of the intake? That would just be plugged into a stock boost gauge cluster? Just want to be sure I am on the same page here
yes, the blue goes to the brake booster, be sure to put in a one-way check valve to prevent boost going to your brake booster. the port next to the blue can be use for an aftermarket boost gauge if you are running one.
sxracerb25
Car: 1990 Nissan 240sx
one way check valve? what would happen with boost going to the booster?
240z4u
Car: '95 Nissan 240SX
Don't most nissans come with a check valve?
Evan
DriftX
Car: '89 240sx
Mine doesn't have a check valve on my brake booster - that's prob my problem lol
lilskyline240
Car: 90 240sx w/ rb30det
it should have? its in the middle of the stock brake booster line halfway across the firewall
DriftX
Car: '89 240sx
lilskyline240 wrote:it should have? its in the middle of the stock brake booster line halfway across the firewall
gotcha! Under close inspection, it's behind a clamp of sorts. Damn ninja valve.
