Anyone know what ecu tuner might have done this? sr20det redtop
Dcasil80slider
Car: 1993 240sx se sr20det fastback 5speed
Ok this is the ecu out of my 93 240sx with a redtop sr20det, trying to figure out who has chipped it. i confirmed that it is not a jim wolf unit or a e-mance unit so anyone have any ideas ?
Dcasil80slider
what strikes me odd is that my ecu sticker on the cover is black and every other s13 sr ecu i have seen had a red sticker with a 62 on it. so anyone have any ideas ????
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
It does say reman on it so that might explain the sticker. As far as what is on the chip, it's hard to say. You'll have to have someone with a chip reader take a look at it and figure it out.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Some japanese company that either re-maned fryed ECU's for Nissan and/or had factory ok to modify stock ECU's (and then installed a re-maned sticker for legal/emission purposes?) I don't know, but those are my guesses.
dtowndrifter
Car: s-14 kouki
The ECU that came with my redtop swap looks exactly like yours...I have a stock ecu and the chipped one...When i put in the chipped one the car feels like a totally different car...Way, way faster with the chipped one in..But for some reason i have to put in the EGI fuse for the car to start..Also if i leave the fuse in over night my battery will be dead.. on the stock ecu it doesnt need the egi fuse nor will it die..Never got around to figuring this problem out..O yea my chipped ecu has a speed cut in it...My stock one doesnt..
So i never use my chipped ecu cause of the speed cut and my battery dying..
red04r1
that almost looks like a nistune board
Dcasil80slider
can anyone verify if this is a nistune board or not ? and can i just unplug the daughterboard and if i do will the ecu run the engine like a stock ecu ???
dtowndrifter
Car: s-14 kouki
I would'nt unplugg it...
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Definitely not a nistune board. If you want to take it out you have to move a board component from cj2 back to cj1. If you want to send it to me I can read the chips and try to figure out what it is set up for.
