anyone know the part #'s for the power steering lines for SR swap?
Wuss
I was hoping this was something I could pick up at my local Nissan dealer, being that I haven't had any luck sourcing them online.
All I basically need are the few hoses that come out of the power steering resevoir, correct?
Does anyone have part numbers?
Thanks.
SpeedRacer1
Car: 1990 240SX, G35
49710-53F00 That should be for the 1991-1994 DOHC High pressure line. The lines can be sourced at LS Auto for $350 (yeah right!), Nissan will not be much cheaper, look for the lines to run about $280. I would check junkyards, my friend and I found two high pressure lines at a local junkyard, they wanted $50 each, so we both bought one.
The pieces needed for power steering:1 Steering fluid resevoir (the SOHC one is the same as the DOHC)1 pipe that feeds fluid to the pump1 power steering pump, preferably SR1 high pressure line (this is an expensive piece)1 steering rack (should be on the car already :P)1 low pressure line (can be made since its under low pressure) this feeds back into the resevoir completing the Non-Hicas power steering chain.
quiksilvia
Car: 95 s14 se
i got my lines from a guy on nico, ask around
