anyone know the correct psi of electric fuel pump on an E1
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
jeepinjakear15
Car: 1965 Datsun L-320 1997 Grand Cherokee 2002 Acura 3.2 TL Type S
trying to get fuel into the carburator so i can drive it!
PEZi
ah man... i don't know any stock specs for that... but remember that carbs call for decently low PSI... my weber only runs at 3.5
jeepinjakear15
ive still got the nikki on there so a pump that isnt so a pump thats like 5 to 7psi should be ok?
NL320what
Car: '63 Datsun NL320 4x4
'04 GMC Yukon
'13 Chrysler 200 Touring
any pump will work, invest in a pressure regulator to adj if needed. around 4psi is good.
jeepinjakear15
I put a 4 psi pump in there and and it's over fueling it
jeepinjakear15
Is the datsun slp310 roadster pump the same as an e1
NL320what
'04 GMC Yukon
niki carbs are really close to the following model replaced by hitachi dch. might be a needle or seat prob. but a regulator from parts stores work good and the dial is labeled with psi increments. its either a carb or pressure problem.
jeepinjakear15 wrote:I put a 4 psi pump in there and and it's over fueling it
Return to “Datsun 320”
