480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sat Jan 24, 2009 4:50 pm
Run a restrictor on the turbo. .63, you can find this on JGS's webpage or you can get it through McMaster-Carr, go to the DIY oil line thread in the Ka-T info sticky.
These CRX kits are made from the same core components as the ebay kits. The only difference is CRX marks their kits up, so you pay more for the same stuff. Made in China. Roll the dice on your daily driver..
CRX is a pretty good place to get an intercooler kit from though.
If you guys had done some research you would have found that the budget Ka-T t2 build is a much more reliable and MUCH better option. Bottom mount ebay manifold(tried and true), stock injectors, FMU, 8 psi, running and boostin for years with no problems. You will never get that out of the Chinese turbos and top mount manifolds.
