Anyone know if the OEM wheels off a Lexus IS 250/350 will Fit?
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
They have the same bolt pattern and Front:18 x 8 offset is 45mm Rear:18 x 8.5 offset is 50mm.
The Newer wheels come in a "smoked" Color.
amitlaCOUPE
Car: Dark Slate Altima Coupe 2.5
nope they wont fit, i tried
mpbclutch33
Really?? Why didn't they? Did something Rub?
amitlaCOUPE
well when i took my car to the tire center, they tried fitting the rim before applying the tires and they said the holes were to small and the only way the rims would fit my car was to get them drilled but its not recommended.
TheBourneAltimatum
Car: 2007 super black nissan altima 2.5s
yeah lexus uses the same bolt pattern as BMW's and Mercedez... which i believ is 5x110 but i'm not a 100% sure
losenone
Car: AC 3.5 CVT K12
NO, the bolt pattern is different. The wheel will fit, but the bolts are a different shape. You just need to get the right ones, I fit wheels from an IS on mine and I needed new bolts. $10 at STS.
mikegtr06
Car: 1995 180sx
so the studs are just different sized ?
losenone
Car: AC 3.5 CVT K12
Yes, they are just cut differently. Maybe one is metric and vice versa but they dont fit!
EDIT: This should also be in Suspension Brakes and Tires forum FYI
Modified by losenone at 10:14 PM 10/13/2008
