Anyone know how to install OIL PSI Gauge? and temp gauge..
ZOOMIGUEL
Car: 1989 240sx SR20DET
2006 Lexus IS250 AWD
I bought my sr20 and the temp gauge is not working on the cluster so i have an aftermarket gauge. but i do not know how to install it!
HELP! i dont want my sr to overheat ;(
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Oil pressure gauge tap in to the stock oil pressure sensor with some fittings. To get your stock temp gauge to work pull your gauge cluster and on the back where your temp gauge is at there should be a diagram on the thin film. On the far left plug the top left wire is your signal wire. If you fallow it it should go to a spot with a screw into the back of the cluster and should say tm. Cut that wire and solder a wire to. The cut wire on the cluster end and run that wire all the way to the single wire coolant temp wire next to the throttle body. You can cut that plug and run your wire with the stock plug with some solder or butt connectors. I you got any questions let me know.
s13-t
Car: s13 pig nose w/blacktop sr20det
or buy a water neck adapter...
ZOOMIGUEL
will try this tomorrow!!!
