anyone know any writeup on how to retrofit bi xenon projector to a 2001 maxima
D_roc
Car: 2001 Maxima 20th aniv edition
i know ebay have some cheap ones but i like the 20th aniv headlight and i want to keep it that way a single bulb light wiht a bi xenon projector but not really sure how to crack open the headlight lens or how to retrofit a projectorthanksD
Darktide
as far as a retrofit I couldn't help you. I just put a bi-xenon HID kit into my '00 lens. Regardless of what everyone else says no one has given me a link to the actual law that states it's illegal. Only links to a page stating that a group of people think it should be. Well /rantoff
To crack open the lens, I believe the process is preheating an oven to 200deg and placing the lens into it for a few minutes. It'll soften up the glue holding the two pieces together and then you just need to take a screwdriver or butter knife and separate the pieces. I've seen a lot of variations of the time/temperature. The basic thing to understand is that with a lower temperature you get a much larger room for error versus a higher temp which gives you a smaller window where the glue is loose to when your lens is melting. I've heard some people wet a towel and wrap the lens in it so that it protects the lens from melting but still allows the heat to get to the glue to soften it up.
After that, you're on your own. Sorry I couldn't be more help to you.
D_roc
can you please post a pic of the headlight i want to see how it looks and about the law screw that idc what the law say they didn't buy me my car i just want to do it w/o messing the whole thing i'm not really good wiht creating thing only fixing
Darktide
I'm just letting you know that if someone knows their stuff they could give you a real hard time. The other law that could kick you is that if a headlamp has a 'DOT' stamp on it you can't alter it. But beyond that
I haven't done this myself. I've done other vehicles but not my max. I haven't had a need to remove the headlights or alter them at all so I'm not much help. Good luck
