silpena »
https://forums.nicoclub.com/silpena-u34788.html
Wed Aug 15, 2007 9:20 pm
anyone know if theres anyway i can get a return bung to my oil pan without welding it. I could get it taken off but i tried once and was pissed so much i gave up i jacked it and losen the mounts my hands are to damn big! my jdm friend could do it he has small hands but hes too busy. anyways thinking of going with a cheap turbo build this year with hella used parts and junk yards finds goal is under 1,500 and little labor work(well mostly almost no labor work) I was thinking maybe use the oil drain plus and use that for the oil return for my turbo? i mean think of it can't i get a fitting to go in there and also use to lube my turbo. I would just take it off when i need to change my oil and boom! done. No welding, no removing oil pan, no nothing! i think i might look into it and try to make something for it to reduce ka-t build's. any thoughts?spec's on my build for the year is so far something like this:$50 used turbo from junkyard(might buy 2 just in case)choices are mostly old vovlos, mercades, a plymoth laser, 300 zx(1987)used turbo manifold(80-120)anything will do ebay intercooler and hot pipe/ cold pipe(140-190) maybe used if i can find one all gauges(250-300) a/f, boost, oil pressuresr20 injectors(70-100) easy to findgreddy emanage(200-300 or less idk)wide band(190-240) a good oneall lines and fittingcolder plugs ngk heat range 2? new wires and rotor n stuff(around 300) all could be less idk i can find some good deals here on nice or craigslist or ebayanything missing i know something is missingmy goal is around 225whp and around 240 rwtq i don't need alot of power i'm not into the big power and wear my motor out it only has 101,000 orginal miles i just replaced the head gasket since it blew from overheating( my bad on not replacing the water pump fast enough and thermostat my dad told not too and i listened to him he bought the car so idc his fualt)car runs great i'm gonna get a compression check and leak down test soon. Compression should be higher then normal since i shaved the head by like 0.0014. My car has a slush box so that ain;t cool at all but thats why i'm keeping the power low so i don't blow it. I'm looking to for something fun i don;t race, drift or anything just like to have some fun wih my car some times Oh if anyone wants to know my 240 is a 93 se model with super hicas(bummer but idc doesn't bother me i go to tracks) autoi bought the car 2 yrs ago with only 76,000! for 2,700 lucky find around my small area guy wanted 3,400 but i got him down(bastard tried to hide body defect) its a good thing i know how to do body work i can maintaine or change my paint whenever i want or fix any dents if i want.
