Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Fri Mar 05, 2004 2:34 pm
Without looking at the FSM, I can tell you with 99% certainty that there ARE different grades for both rod AND main bearings. Nissan is anal retentive about clearances (thank you Nissan!) so I'm certain that there are different rod bearing grades offered by Nissan. If you cant find them, then you could order up a set of Clevite 77's, they are most likely made for SR20DE's too. I KNOW Clevites offer different grades. Also, if you get a grade that is too thick, its not too hard for the machine shop to hone out the rods to fit the new bearings perfectly. My recommendation to you at this point is to print out the engine mechanical section of the FSM, take it to the machine shop, explain you are having a hard time figuring out the bearings that you need and want them to do it, and order them for you. Give them free liscense to hone out the big ends of the rods, align hone the mains etc. to fit the bearings in with proper clearances. It might cost more but trust me, a perfectly rebuilt motor is worth every penny.
