Anyone? KA rod bearings.
andrewhuffman
Car: 1991 240sx
So nissan uses he grading system for bearings... In the FSM, it says the main use grades, and rods use grades.
Now, nissan offers a STD size on the main, and individual grades for the rods.
1st, is the nissan STD set good for them mains?2nd, how can i tell what grade i need? One side has the rod number, on the other side of the rod/cap, there is a 5, 2, 0. what number am i looking for?
eazye2000
Car: S13 KA-DET
Not sure if this helps, but here it goes.
I had my crank mic'd and micro polished. Looked good to order some standard sized rod and main bearings. I called AMS and ordered bearings along with rods and such from them. I didn't recall reading about anything with the grades/colors/numbers thing. I thought that was only on the SR's?
Anyways, there's some personal info.
andrewhuffman
Car: 1991 240sx
thanks for the reply... when using aftermarket rods, that goes out the window. And if material is taken off the crank, it goes out the window. I may just have the crank polished to match std bearing.
480sx
Car: 1996 Pearl White 240sx
You buy your 'grade' of rod bearing by thickness, or clearances. Its best to bring your block to a machine shop and mic it out, then recommend one of the 3 different bearings.
I think somewhere in the FSM it tells you how to read the crank for that, but if your using a used crank you really should have it measured to make sure clearances are optimal.
Thicknesses of std size rod bearings available. Grade 0 - .0593-.0594 (in)Grade 1 - .0594-.0595Grade 2 - .0595-.0596
