C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jan 02, 2009 8:32 am
Just a fair warning to potential buyers. The electonics of the OE nav system is not a plug and play. The main harness is very different between nav and non-nav vehicles. Either some serious wiring work will need to be done or the proper main harness will need to be purchased and installed into the car.
To the OP. You might consider using the existing nav screen as a secondary display for the stereo. Most decks with built-in screens have the ability to output to a second source. You could easily display video on the OE nav screen while displaying the navigation on the deck itself. If I were ever inclined to replace the stock system with a nav equipped stereo, this is probably the route I'd take.
