Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Sun Apr 11, 2010 6:01 pm
I really don't mean to be a Debbie Downer, but the fine vision instrument cluster (came standard on all 01-03 QX4's) is only plug'n'play with the 2004 Nissan Pathfinder Platinum, since that was the only Pathfinder than came with the fine vision cluster from the factory. Another NICO member tried swapping a fine vision meter into his Pathfinder (that came without the fine vision meter) and some things did not work, such as the electroluminescent illumination as well as the 4WD indicator and a few other indicators.
I do think it would be possible to wire up the gauges to work perfectly in a Pathfinder, but it will take some work. You would need to swap some wires in the harness to make sure the proper indicators work as well as removing the bulbs from some indicators so they don't stay lit (like the TMPS indicator, unless your Pathfinder came with TPMS).
