Anyone here using a KA-E MAF?
ilovecoupes
I know they aren't the exact same. but im having trouble with my car, and i have a KA-e maf. So I want to swap the two and see if it helps my situation
I just want to hear some first hand experince with them.
Do you run EXTREMELY rich?Does it run like ****?etc....
thanks,Joe
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
Ran the ka-e maf all last summer, without updating the map on the ecu... basically it ran, and have not had any problems with the car performing. I have a narrow band a/f gauge, and it reads optimal till i go over 3k rpms which is where the map starts to change, then it just rich from there.
Two-Fortee
Car: 180sx.
trevr wrote:Ran the ka-e maf all last summer, without updating the map on the ecu... basically it ran, and have not had any problems with the car performing. I have a narrow band a/f gauge, and it reads optimal till i go over 3k rpms which is where the map starts to change, then it just rich from there.
If it ran rich, then would this be a good option for someone using a T28 and no tune on a ca18? I have all the basic upgrades done, but right now I'm looking for a simple tune. Would this work?
ilovecoupes
trevr wrote: then it just rich from there.
how rich are we talking?
thanks for replying.
jt15833
Car: 95' 240SX
it may WORK, but it is by no means a tune. I would never run that. It's basically saying well these mods will make my car run lean, and these mods will make it run rich, perfect!
if you're looking for a simple tune try an s-afc or a rom tune. Poor tuning is a good way to destroy your engine.
Two-Fortee
Car: 180sx.
ok thanks man !
float_6969
The SAFC can fix the KAE MAFS overfueling problems.
IMHO, the SAFC is a great tune for mild changes to the fuel map.
It's when you're trying to use it to compensate for LOTS of changes that I have a problem with it.
rico05
Car: 1992 RMS13 w/ CA18DET
I ran one for 3 years with a stock ROM. Runs much better with a proper tune now.
