um no, either way it ends up just being the bosch pump actually doing the work for both setups, the bosch will just over power the walbro in this case..krayton wrote:isnt that only gonna run what the 255 can push?
cant you just run a sump like all the aussies do?
255 fills the sump up and your aftermarket inline fuel gets it from there
yeah, I meant the actual housing for the pump itself that its attached to, like that intank assembly, that the fuel lines come up and out of.Carl H wrote:housing on the 044 appears to be aluminum... has threaded fittings on the top, metric but i forget the pitch.
the Denso is a nice piece for sure. OEM reliability and quietness. However, if you want more than about 450 whp the Denso will drop fuel pressure. I had mine hard wired to keep the volts up but it pulls too many amps for the stock wiring from the lid to the pump itself. If you read the reviews/tests everyone says its a great pump if you can supply the voltage and current, which is easier said than done. That is why a lot of ppl can push more whp out of the walbros despite the flow #s. The walbros require less currentrbsileighty wrote:MKIV and 3SI both show good things about the Denso unit... still my favorite (I am running a single) because of the flow and the noise... very quiet
There are some things to save money on and some places you shouldn't... your motor needs fuel, so I'd be reluctant to save ~$100 for the $ of damages that could be incurred from being thrifty
Thats why I'm changing my setup. I plan to leave the intank walbro. Keep that line running all the way up to the front of the car.rbsileighty wrote:MKIV and 3SI both show good things about the Denso unit... still my favorite (I am running a single) because of the flow and the noise... very quiet
To late I'm already half way done with my new setup it was pretty cake. I'll do a write up for all to see sometime this weekend early next week, and get some calcs as well to see what it will actually flow.gawdzilla wrote:if i were in your situation i'd run the 044 in tank. harder to fit but in the end will be less headache. that's the setup carl is running.
