anyone here running power fc d-jetro??
drftnrps13
ok i wanna get a power fc d-jetro for my rb26, just wantded to know how hard is it to wire in the map sensors??? do u just use the orignal maf wires and re pin the connector for the map or do u need to run ur own wires? does it come with instructions on how todo this?? thanks
gawdzilla
Car: none
the instructions are pretty clear (even though in japanese) on how to wire it. you splice them in to the 2 wires that go into the ECU for the maf. the map harness plugs into the pfc itself so your splice is closer to the ecu, not by where the maf sensor connectors are in the engine bay.
theres a few ways to physically connect the map sensord, and most ppl seem to like using the pcv localation and T'ing the boost/vac signal
