Ilya »
https://forums.nicoclub.com/ilya-u159401.html
Sat Jul 23, 2016 7:45 am
To make a long story short, I purchased an old Gen 1 Kawasaki KLR 650 for $1,500. It's a 1989 with 19.6kmi on it.
Put about $800 into it already with fluids, pads, chain, sprockets, etc.
Bike ran pretty dang good all things considered. Was told that at this mileage, I would be smart to change the 'doohickey' (balance sprocket parts) inside the left cover of the engine.
I decided that while draining the oil, I would in fact go ahead and do it and 'kill two birds with one stone'.
Haven't had it running since.
1) Drained oil
2) Took off left cover
3) Decided it was too complex looking for me to do, so decided to only change the oil and not do anything with the engine/doohickey
4) Installed a new gasket and put the cover back on, filled with new oil
5) Bike just turns over and over and over, won't start
6) Take off cover again...notice that stator has a cut wire. I'm assuming bad solder from previous owner and I broke it while taking the cover off
7) Order new stator
8) While installing new stator I decided to try the engine upgrades. I get the rotor retainer bolt off but can not for the life of me (impact gun, long breaker bars, special rotor puller tools) get the rotor bolt to break the rotor free. Give up on that and go back to trying to fix the starting issue
9) Install new stator along with another new gasket (sprung a leak on the other one)
10 Bike still will not start. Just turns over and over.
I've checked spark, definitely getting that. As far as I can tell, fuel is fine. Petcock was working good before that...
How could I possibly have broken my bike by removing the cover? It started pretty much immediately before that.
