savatoge »
https://forums.nicoclub.com/savatoge-u28467.html
Wed Jan 11, 2006 12:00 pm
General knowledge (and in the FSM too?) is that the KA can be bored over a max of 1mm (.040") to arrive at a bore of 90mm. Going beyond an overbore of 90mm results in cylinder walls that are too thin to operate in a reliable and safe manner. Have you spoken with the people that would be working on your block? If so, have you discussed what final bore dimensions your block will have?
The stroker kit web page here:http://www.importperformancepa....html...provides specs on the new displacement:With Original CC's = 2389cc'sNew 102mm stroke.Max cc's 2621 (90.5mm bore)
I looked into this stroker kit several months ago, as I was curious about the details concerning the kit and what all it entailed. What's interesting is that before I called Flatlander Racing about this stroker kit, the web page had the following listed:
With Original CC's = 2389cc'sNew 102mm stroke.Max cc's 2614 (90.5mm bore)
(I calculated 2625cc's given the above bore and stroke...a stroke of 101.5mm will give 2614cc's. Why did they round up on the stroke measurement? No need to artificially inflate the numbers, is there? Also, I have my head displacement at 43 cc's. Is that correct? Maybe that's where my calculations differ from theirs)
In that portion of the page, they had listed the displacement change as a net of an additional 225 cc's. But at the top of the page, it also had listed:"IPP's stroker kit consists of 5.5mm more stroke that when added to the increased bore = 440cc more cubes of usable power!"
So, now operating at 2829 cc's and a stroke of 101.5mm (don't know why the switch to 5.5mm more stroke, when they listed 102mm earlier)), the bore would now have to be 94.18mm, meaning an overbore of a whopping 5.18mm.
While I was on the phone with one of their reps, I asked about why the numbers on their site didn't work out right...he said that the page was relatively new and that they were "working out the kinks"...take that for what you will. Anyway, if you're going turbo on the KA, they don't suggest going above 1mm (or .040") overbore. 90mm is their recommend bore limit on the KA for turbo applications. If you're going for a NA setup, they recommend up to 1.5mm over (.060") and high compression pistons...the guy said that in their records he saw where someone got a KA bored over at 2mm (.080")! I asked if he had any data on the sonic testing for the 2mm overbore and he said that they didn't keep records like that around for long. Seems to me that on a block like the KA24, where you know you might have problems on a consistent basis by going too high on the overbore, you might want to keep that kind of information around.
As far as a stroker kit goes, I would only go with one if you are going to stay NA. If you're going forced induction, I would take the money that you were spending on the stroker kit and put it towards some forged pistons, standard length forged connecting rods, as well as upgraded valvetrain componentry and cams. I think you would be very pleased with the end result, not to mention a more reliable motor configuration.
Modified by savatoge at 3:46 PM 1/11/2006
