Anyone heard of Soda Blasting?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
So I stumbled upon this yesterday when looking for paintless dent removal shops...
http://www.sodaworks.com/
It looks like a nice alternative to sand blasting especially for delicate surfaces...
Does anyone have any experience with this?
PapaSmurf2k3
Site Admin
I've heard of it, and I might have even done it once, but I can't quite remember. For some reason I'm thinking that it worked well. Whatcha blastin big guy?
College kids these days and their sick fetishes
elwesso
2007 BMW M Coupe
well this summer I'd like to paint my car, and I have a couple areas that need sand blasted due to rust.. I just stumbled upon this, since I was thinking about buying a sand blaster (I have other uses for it around the marina).. but this might be a nice alternative..
Dieselman
Car: 07 Ram 3500 Cummins Diesel.
Wes there's a ton of different types of media blasting, soda, glass bead, shell's .... all have their own particular application.
Soda is great on thinner metal such as auto body. Less stress distortion and heat distortion on the metal.
Razi
Car: Moo
Are those areas mostly seams?
Broadfield used a Speedblaster, which looks like it's perfect for (or made for) blasting seams.
And apparently if you keep it pressed against the metal, it sucks the media back in.
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Used it to finish up two rusted Austin Healeys after sandblasting. Preserves the metal quite well and a hell of a lot easier to clean up than sand.
themadscientist
Apparently in Japanese soda blasting is called nyuki nyuki.
[youtube]http://www.youtube.com/watch?v=_c1dNTB-MPA[/youtube]
I knew it was a euphemism! I bet it involves octopus.
themadscientist
9 peckered demons and schoolgirls as well.
elwesso
2007 BMW M Coupe
Very interesting. Thanks for the info :). I wonder if the soda machines can use other media if something more abrasive is needed.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
themadscientist wrote:9 peckered demons and schoolgirls as well.
:spitout:
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
I've heard of "soda blasting" in 3 different contexts
1. dropping mentos tablets into a full 2 liter diet coke bottles. My son's done it with 7 in one shot, with a small drilled hole in the bottlecap. Watched a 50' geyser, very cool, very messy if you're too close.
2. the loud gaseous emissions people make after drinking large amounts of carbonated beverages, while describing Nala's sex life.
3. paint stripping/refinishing with baking soda with air pressure. If your intention is to use it for stripping a car's finish, you might want to double check with the paint manufacturer you plan to use to repaint. Not all recommend it.
Bubba1 wrote: 2. the loud gaseous emissions people make after drinking large amounts of carbonated beverages, while describing Nala's sex life.
:lolling:
PapaSmurf2k3
Site Admin
I wonder if the mid westerners call it pop blasting, and these crazy southern bastads call it coke blasting.
Clearly "soda" blasting is the correct answer, but these stubborn people just don't get it!
alms24sebring
'04 Nissan Sentra SER SpecV
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
I was looking through the harbors freight web site and found some soda blasters for cheap. I been seeing videos of teh soda blaster and looks like there pretty cool. I think I shall buy one.
Bwana
Car: Denali
PapaSmurf2k3 wrote: and these crazy southern bastads call it coke blasting.!
Pretty sure that one carries a different, laxative oriented connotation.
Ace 2.0
Car: z32 2+2,1987 CRX si
i read that sodablasting could be used on cam and such to work harden the surface while not deforming the lobes,also that the microscopic divets that are left hold oil better than unpeened lobes.
makes sense.
OwnerCS
Wes - You betcha.. I had to clean up the battery box area.. I don't need to tell you about what happens under the freaking battery box.. :bigthumb:
Initially I used soda from Harbor Freight.
Bought a little unit like the following for $20 from Harbor Freight and rented a kick azz gas powered compressor for the weekend for under $50..
As I recall, I found the best deal on (black diamond) media at place named Tractor Supply (TSC) as it is used to clean up rusty equipment.
http://www.harborfreight.com/portable-a ... 37025.html
The only down side to the black diamond media is takes forever to get it out of cracks and crevices.. If the soda media disolves with water, then it is worth the extra cost.
