Shocker wrote:Most likely restrictor related. Generally journal bearings only need a -3 line hooked to them, however some require a small restrictor. After my issues with my 35r I just made sure Precision supplied w/e restrictor was needed for my 67mm.
Making your own bearings is possible if you have the right machine tools. However as cheap as rebuild kits are for them I wouldn't waste my time. If the wheel scrapped the housing to much it most likely will need a rebalanced otherwise you might pre-maturely kill off more bearings...
Well The guy Michael From Precision said Journal bearing turbo's dont require restrictors, But Ball bearing turbo's do.
What is the Diameter of the -3 line? I will have to check my size.
The Turbine wheel Just Barely scrapped the housing. It didnt make any type of groves or anything. Just Barely turned shiny. I don't believe it needs any balancing. I luckly caught it quickly.
But if you guys are killing turbo's with to big of an oil line, I need to look into that.
But something has caused it to go out quickly. So I would like to find it before I kill another lol
