Anyone have tried to put a S15 steering wheel on a S14?
makkd
I bought a S15 steering wheel that comes with an airbag a
month ago. My car is a 95 nissan 240sx with round eyes. What
part do i need in order for the airbag of the steering wheel to
work. Anyone have done this before? Please help, thanks~
lateralmotion
Car: guitar, skateboarding, driving
have you tried already? Is the problem just the wire connections
makkd
it is on my car, no problem with steering,.. the only problem for me is how to get the airbags back to work,... coz the connection plug for airbag is not really match,.. i have taken the whole control reel out,.. which means my car is lack of both horn and airbags at the moment~
MikeS14240sx
Car: 98 Nissan 240SX
Your probably going to have to find out which wires are which of the airbag and just manually connect them. I would soider and use heat shrinks to make the connections. Stay away form using butt connecters
vtund777
Car: V-tun'd S14.5
I have a 96 and the plugs were the same. It was pretty straight forward as a plug and play mod. It took 30 minutes. I'm not sure if there were any differences in the air bag plugs between the 95 and 96 years, but i'm assuming it should be the same. The only thing I couldn't connect the the cruise control, but who needs that...
rocketman240
Car: 1995 Nissan 240sx se
I had no problems with the plug on my '95. I did a write up on the last person who asked about installing S15 wheel on S14. Search next time.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Why in the hell is everyone bumping old threads all of a sudden? This thread is almost 7 years old...
