http://www.apexi-usa.com/produ...Num=1
On that webpage one of the documents should have the colors, if you have a s13 then u dont need to do what i did. I think you should use the n3-b which is the one that koukiKA240 said.
Just compare your ecu with the diagram if it is the same then there should not be any problem.
