missionsix43 »
https://forums.nicoclub.com/missionsix43-u51576.html
Wed Apr 04, 2007 8:31 pm
Well yes, it will be stable with all 3 corners down, but then i sort of just keep guessing as to what the timing is, tighten it down and recheck, loosen, move, tighten down, recheck, etc etc.
No codes with either CAS.
Timing is with using the loop, I tried the pain in the *** sparkplug method once and it read exactly the same.
This is not a thread about how my timing is off anyways, it doesnt matter how I check it, I'm talking about the cam sensors fluctuating their readings because you put a slight amount of pressure on one side.
