anyone have problems programming key FOB's?
TXCumtrensh
Car: None
Ive got the directions directly from the FSM, PLace the key in several times, emergency lights flash 2 times, you hit the key, and its supposed to program, I have a brand new CR2025 battery installed. I wonder if someone can help me on what serial number i should be using. KBRASZU07.. 2UNBD is printed on the circuit board under beneath the battery.
any advice guys?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Match the FCC number.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
TXCumtrensh wrote:Ive got the directions directly from the FSM, PLace the key in several times, emergency lights flash 2 times, you hit the key, and its supposed to program, I have a brand new CR2025 battery installed. I wonder if someone can help me on what serial number i should be using. KBRASZU07.. 2UNBD is printed on the circuit board under beneath the battery.
any advice guys?
Is this the procedure you use? http://www.q45.org/remote.html
like brian said, match the FCCID..... last 4 digits should be A0473 or 078
bsw357
Car: 98 Infiniti Q45 and 8 others
If this is for a 98 y33 KBRASZU07 would be the correct remote for the car.
Programing procedure should be http://www.q45.org/y33remote.html for this year model. However I'm kind of stuck in the program mode. After turning the ignition to ACC, then press a button on the remote. the car responds by flashing the hazard lights but remote wouldn't work after I turn off the ignition and open the door. I tired different twists with no successful result. The only way to get out of the programing mode seems to be a hard reset by disconnecting the battery for a while. Otherwise I can't get back to the initiation process again. I'm guessing there is another step after the car responding to the remote to complete the programming process? Any help would be appreciated.
bsw357
I finally got it programmed, the procedure on the manual didn't work for my car.
Below is the procedure worked for my car.
1.) Close all doors and lock driver side door.
2.) Insert and remove the key from the ignition more than six times within 10 seconds.
(The hazard warning lamp will flash twice.)
3.) Unlock and lock all doors with Power door lock switch.
4.) Push any button on the new remote controller once. (The hazard warning lamp will flash twice.)
I didn't even have to have the key turned to "ACC" or even in the ignition switch.
Previously I couldn't get the remote programmed properly, by following the original procedure. The car would respond at the step 4. and flash the hazard warning lamp twice. but the remote wouldn't work, I can't even get out of the programming mode until I disconnect the battery for a moment.
This method worked for my 98 Q45. I hope somebody can put this info to a good use someday.
