SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Feb 21, 2009 11:10 am
For some time now I have been following along with the Road Crown related leading issues that you guys were talking about and dealing with.
In a thread here I remember reading about someone installing Michelin Primacies to resolve leading issues on the highways. There is not a component that can be "corrected" it can however be counteracted by installing certain types of tires. For those who drive their M daily with very little need to a performance tire than the Primacies would be a decent choice.
However, Yesterday I had the privilege of meeting a very friendly gentleman with a low mileage 06 M35x. He has these Primacies with ~1500 miles on them. (see the photos below) During my routine inspection of the tires during the oil change I noticed the front tires were exhibiting signs of feather edging. I performed rotation and balance and an alignment for my own curiosity. I found that the camber was in spec (~0.5 degrees of negative camber) total toe was a little out (spec is 0.1 plus of minus 0.05 I think, don't hold me to that) the observed initial total toe was 0.28 (0.14* on each front wheel).
My goal of this is to consolidate some information on the tires solutions that some of the owners have found. You guys are helping me do what I can to help you. I will try to compile a list and submit it to Infiniti as a potential recommendation. There does not appear to be much of a solution to this as any alteration will have ramifications in other systems that will alter the overall driving experience in a negative way.
(yes,that is a Nico calender in the back round and part of my undersized tool box)
To prevent any further damage to these tires I dual plane balanced them, whomever installed them only mounted weights on the rim (single plane, or static balance) I also placed the RF on the LR and LF to RR to try to smooth out the edges of the tires. This another pro for the Primacies, the Contis cannot be cross rotated without being dismounted ($$$).
I am hoping that these tires are worn due to total toe being out of spec. I would really like to find a tire that for most drivers will help balance out the road by absorbing any deviation that the tight suspension will not allow for.
The Continentals also work well although I have yet to come across an M owner that is either interested in or in need of tires since I have began hunting for one, so I need your help as there are many more people here with Ms that take interest in this kind of thing.
Thank you all for your participation and sorry for the rant.
Steve
