O5Q45 wrote:Thanks Ed, I hadn't thought about checking the oil for a head gasket breach. I assume the oil would be milky?? Or;
I ordered the premium radiator off rock auto but they only had two choices. The spectra was 114$ so it was most expensive and I assume better quality? Also new thermostat and Nissan Green concentrated coolant.. I would have got the Blue but it wasn't going to ship from Amazon until Dec 10!!! Hope the greens the right choice and I hope one gallon of concentrate is enough for it doubled up with water..
Yes, the oil could be milky if you checked the dipstick soon. Eventually the water settles at the bottom and your dipstick would only show the oil, maybe even show it as overfilled, depending on how much water crossed over. I usually drain my oil and transfer it to settle in jugs so I can see such things.
Also, look at the coolant reservoir. Is it past full level? Does it have an oily sheen? Another way is to pop the valve covers
O5Q45 wrote:Also, we noticed the morning before this happened, it was 34 degrees and I could not get heat very well.. it was warm coming out, but usually when it's set to 90 it gets HOT, not just like warm... Was this indicative of something? The temp gauge was in its normal zone...
Was the air blowing cold when stationary, but getting warmer when at speed?
The immediate indication to me is that you were losing coolant. Since your heater core depends on hot coolant circulated thru it and the fan to blow air - you were not getting enough coolant.
You'd either lose it by dripping below, or seeing the white smoke from the tailpipe.
... or you had enough coolant in there, it just wasn't being circulated efficiently to pick up heat. I haven't seen many nissan water pumps go bad, but it's very accessible in the VK, so I'd check to see if the blades are good.
