anyone have any problems with wheel offset after installing tein coilovers ?
NOAH041283
Car: S14 240SX SR20DET
~4N~
What do you mean? Are you worried about the wheels being sunken, sticking out, not clearing the coilovers? Give some specs on how low you're planning on dropping your car, which Tein coilovers you're using, your wheel size, offset, and tire size. Then people will be able to give you some better advice.
NOAH041283
I am using tein type hr coil overs and i was wanting to but some wheels that are 18x8 +40mm but i pretty sure they will not work because the wheels i have now are 16x7 +38 mm and the tire is touching the coilover the tires are 225 50 16 they are a little wide i guess but the wheel is close and 8 wide will be even closer and more offset too i was just wondering if anyone else was having this problem too and if some 350z wheels like the track wheels or some of the g35 wheels will work their offset is in the mid to low 30s
thanks noah
NOAH041283
BUMP
whiterps13
Car: white LE hatch
Whoa dude, slow down. Please revise that "sentance" with some periods. I got a migrane half way through...
18x8 +40 sucks. You dont want those.
Now, do you have an s13 or s14?
If you have an s14, 350z wheels and the G35 wheels will fit. If you have an s13, ask this dude about his 350z wheels.zer...24211
NOAH041283
I have an s14
NOAH041283
I am using tein type hr coil overs. The wheels i was looking at wheels that are 18x8 +40mm. I pretty sure they will not work because the wheels i have now are 16x7 +38 mm and the tire is touching the coilover. The tires are 225 50 16 they are a little wide i guess. I like the 350z track wheels or some of the g35 wheels will work their offset is in the mid to low 30s. I guess what I wanna know is if i get wheels with a lower offset will they be farther away from my coil overs even if they are wider. I also wanna know if you can even run a 225 in the front. sorry I must have been on crack when I wrote this post. noah
nismofly
Car: 89 Nissan 240SX Hatch
225 was definately too wide for that size, and yes those new sizes would be even worse
350 track wheels are 18x8 +30 front, 18x8.5 +33 rear, not the best sizes but they work pretty good..run a 225/40/18 all around on them and youd be fine
NOAH041283
you can't go wider in the rear looks like there is plenty of room
NOAH041283
by the way the 225 50 16s on the 16x7 +38mm did not rub untill i put on my coil over that is what is driving me nuts
NOAH041283
pump
eddiec
Car: 91 S13
those offsets suk. any wheel with that offset will suk with c/o. either nix the wheels, find other wheels with better offsets, or get some spacers. done. done. and done.
