anyone have any ideas on this KA24DE?
niemczykj
Car: 1992 240sx fastback, 1986 Z31 Turbo
i just thought i should throw this in there incase anyone has anything to say or has a different opinion...when i got the car towed to my house it had no gas in it...i put 5 gallons in and ran it a little to check a few things...but i noticed that my gas gauge just dropped as i sat in the car...and when i drained the oil all the gas came out black mixed with oil...so is the gas mixing with the oil in the oil pan normal for a blown head gasket?...or does anyone think something else isup?
neverlift
I'll attempt to read thru this
that my friend sounds like injectors busted and if you sat and watched 5 gallons drain in 5 minutes or so I'd say all the injectors are blown
or b your rings are non existant,but still to watch the gauge go from 1/4 to none is extreme. Get a volt meter and check the resistance across the injector terminals.
btw a blown head gasket normally blows white smoke after sitting at a light or stop sign.another thing
black=gasblue=oilwhite=coolant
S13DrIfTmEkAnIcS
Car: 89 240sx
pretty sure u got no rings
