Anyone have an extra CA starter for cheap?
damesta
Like the title says, I think mine is starting to go out, email me [email protected]
89'ClubK's
Car: 89' Nissan 240SX
I believe I got a new one from a Pulsar NX. It wasn't too expensive at AutoCrap (autozone). Good Luck!
float_6969
I don't think the FWD starter works. I think you've got to use one from a RWD CA18E(T) out of an S12 (200sx). Also, you can usually get the rebuilt locally for much cheaper and then you know it'll fit.
GoofyATX240
FWD one does work float. I'm using one right now.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
float_6969 wrote:I don't think the FWD starter works. I think you've got to use one from a RWD CA18E(T) out of an S12 (200sx). Also, you can usually get the rebuilt locally for much cheaper and then you know it'll fit.
Only difference is the FWD only has one threaded hole instead of both. Just need to use a longer bolt and put a nut on the end of it.
