Anyone have a squeeking problem at startup w/ new clutch kit and flywheel?
mr_wizard
When I first replaced the clutch for my 91 240, it didn't have any squeeking problems. If it did, it only did so for a split second. Now, pretty much every time I go to start up the car and no matter if I rev in gear or not it squeeks very loud from the clutch area. If I sit there and rev it for awhile the squeeking will go away. But if I shut the car off for a matter of minutes and come back, it squeeks more again and I have to sit there and rev it or just drive it normal for it to go away. The faster the motor is turning the faster you can hear the squeeks. Any idea's whats going on? I don't think it should be affecting anything, but damn it's loud and annoying.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
i had a ranger that had a bad throwout bearing that made the squealing noise your describing, almost like a scraping noise...
mr_wizard
Yeah exactly. ****, maybe I should've put grease on it. But it already had some on it.... not enough maybe?? But if you think about it, the throw-out bearing isn't engaged while in neutral. So why would it be squeeking even if I rev while im not in gear?
91RMKS13
Car: 1992 240sx
Because it wants to
180fan
Car: 89 fastback
yeah I'd suspect the TOB as well.
91RMKS13
Car: 1992 240sx
Now that i think about it I think mine might have been doing the same thing. But now that my clutch has gone out i guess that i will be fixing the squeeking.
Jus14
Car: 97' S14 and 08 Versa
I just installed a clutch masters stg 3 kevlar clutch on mine as well and squeeks under engagement but when disengaged nothin but as soon as you touch the pedal squeeks like something is rubbing did you ever figure this problem out if so what was it i really dont want to pull this thing again....
musk'r
Car: 92 240sx coupe
correct me if im wrong.i think you need to resurface your flywheel or get a new one.for example when you get new brake pads and you of course put em on but dont do anything to the rotors(new ones,resurface) its sqeeks like if it needed pads right.i had the same problem so i went with a better condition flywheel cuz i couldnt find a shop that resurface.so yea
Klits562
Car: white s13 coupe
musk’r wrote:correct me if im wrong.i think you need to resurface your flywheel or get a new one.for example when you get new brake pads and you of course put em on but dont do anything to the rotors(new ones,resurface) its sqeeks like if it needed pads right.i had the same problem so i went with a better condition flywheel cuz i couldnt find a shop that resurface.so yea
makes sensehey neighbor o.O
