Anyone have a parts car?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I need a set of windshield washer nozzles.. Would be great if you had them in green, otherwise I'll have to repaint. I busted off the plastic nipple that the hose attaches to, so I have no windshield washing capabilities right now..
They're back ordered from Infiniti, and they're like $30 each anyway.. :(
OwnerCS
Hey Wes - There is a 96, 94, and 91 at a PnP about 40 miles from me. There is a 99 model less than 10 miles away at UpIt.
Will a 99 work?
If you don't find one by the weekend, I'll be near the one with the G50s over the weekend.
elwesso
2007 BMW M Coupe
I'll need to do a part number check to see if any are compatible, but I'm guessing they probably aren't... Crazier things have happened though. I've lived without this for about 2 months so far, so if it doesn't happen will the weekend then that's OK.
OwnerCS
I can't remember the colors of the G50s. That place is always full of surprises.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Chrome or gold? $125 a pair......
elwesso
2007 BMW M Coupe
I actually am seeing 28933-ZL00A as the part number for a really common Nissan washer nozzle. I'll have to double check and see if they work on the Q.
OwnerCS
I measured the ones on my 91 Q and found 20 mm x 35 mm. Then I measured the 99 I30 and found 18 mm x 25 mm.
The 91 Q nozzles are quite a bit larger than the I30/Maxima nozzles.
