Anyone have a M35 Wheel fitment chart
NICO's V.I.P. styling forum.
Indever44
Car: Infiniti m35
I am wanting to pick up some 20in. Leon Hardiritt's for my 07 M. Since I'm a noob I"m still a little hazzy on what offset is best.Wanting to run a low offset but not sure how low I can go. I'm not wanting to roll or pull the fenders because its my daily. If its a real low offset will I need to run a spacer?
If u have pics of M's running low offset 20's or 19's, I would like to see some.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Welcome to NICO!
And to the VIP Forum. Do you have a set of Harditt's you are looking at already? What are those offsets? Wheel size? Let us know so maybe we can be of a little more assistance.
Indever44
Car: Infiniti m35
Wanting to run the Waffe. I havent purchased yet. Want to make sure of the offset before I drop 3200 on wheels.Front-20x8.5 or 9Rear- 20x9.5 0r 10, I liked to run10.5 but thats not going to happen without some cutting and pulling
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Wow. $3200 for used wheels? Sadly enough, there are few M members here in the VIP Forums. I wish there were more. Hopefully you will be the guinea pig. BTW, it's great to see another Tennessean in here. Lasoyafan is also from Knoxville.
Indever44
Car: Infiniti m35
Going to buy them new. Trying to find out how low I can go on coilovers.
deesy50
Car: 2006 infiniti M35
U don't have to cut anything, cuz our M's dont have an inner lip like some cars.
lawman12
Indever44 wrote: I am wanting to pick up some 20in. Leon Hardiritt's for my 07 M. Since I'm a noob I"m still a little hazzy on what offset is best.Wanting to run a low offset but not sure how low I can go. I'm not wanting to roll or pull the fenders because its my daily. If its a real low offset will I need to run a spacer?
For reference:
OEM 18s 18x8 +47 offsetOEM 19s 19x8.5 +50 offset...
you can see how "weak" this is already.
there are tons of combos that will play into what you can do and what you want. Those low offsets will take some work.
For a "conservative" flush look I am running:
20x8.5 +36 245/3520x10 +38 275/30
my tires are "fat" and not streched and I wouls say +30/31 on the front and +36/+37 on the rear would be perfect for a conservative daily droped on coilovers. These are good for daily and you can see they are fairly flush.
[IMG][/IMG]
if you want more VIP/aggresive offsets like the specs you posted you will need coilovers/bags, stretched tires and will need to do some work on your fenders - if you want in the single 0ffset numbers. Yes our rear fenders are already rolled but with offsets in the teens and below...work will be needed....
this M is on bags and is running specs in the 20s I believe, no body work done so he is going even lower offsets...
[IMG][/IMG]
the lower bags/coilovers will allow the wheels to camber in and thus allow the lower offsets...
Modified by lawman12 at 11:02 AM 12/16/2008
lawman12
deesy50 wrote:U don't have to cut anything, cuz our M's dont have an inner lip like some cars.
wait for this master offseter to post...hehehehe he has probably the most massive lips on a M I have seen....
deesy50
Here's my set up with really low offsets. Sorry, but I can't give my offsets
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
That's sweet. Do you not know what the offsets are or will you just not say?
deesy50
I
jltibbs wrote:That's sweet. Do you not know what the offsets are or will you just not say?
I rather not say.
lawman12
like I said...Deesy be having some offset.....
Indever44
Car: Infiniti m35
Deesy that is what im looking for. I see u have a slight roll in the fender. looks great man what kind of wheels are those?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Meh, no need to hide the numbers.
deesy50
They are VIP Modular
BLACKonBLACK98
Car: Q45, LS400, STS-V
lmao @ i can't give you my offsets. so lame...
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
deesy50 wrote:They are VIP Modular
OK, so I am still learning a lot of the info according to VIP, what does that mean?
BLACKonBLACK98
thats the brand name.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Any contact info on them?
BLACKonBLACK98
http://www.vipmodular.com
they are us made and not hard to get. they also cost a grip (1k+/wheel) and are made to order iirc.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Nice. I like the VR04.
Now if we only knew the offsets, lol.
deesy50
U can just tell them how much lip u want and they will make them.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Sweet. So If I wanted 18x9F w/ a 6" lip and 18x11R w/ an 8" lip they could do it? Baller.
deesy50
Dont know about 8" lip. But for sure 6" its all custom
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Either way, that would be sweet. I could deal with 6" lip all around.
Regardless, Deesy, your offsets, whatever they may be, are sick.
trueno712
Car: infiniti m45
your offset on the m looks insanely sick!!!!!!
mcsniper703
Car: 2009 Altima Base Black
Hi I am wondering if you know how wide the width and deep dish offset of Work VS-XX in 18 and 19 inches that would fit in my car? Thanks.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Some inside info on your current (stock) fitment would be good. I would say (depending on what suspension setup you plan for) 18 x 8 or 9, +35 all around. FWD w/ staggered is FTL.
mcsniper703
jltibbs wrote:Some inside info on your current (stock) fitment would be good. I would say (depending on what suspension setup you plan for) 18 x 8 or 9, +35 all around. FWD w/ staggered is FTL.
Hmm. I would like to do 18x8 front 18x19 in rear but double digit offset 35 sound like not much of difference in lip since the cari s FWD. I pretty much wanted to do deep dish by hitting lowest single digit offset is possible even to roll out the fender, the high-end coilover would be swap in. Thanks.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Well, that's the thing, getting low offset fitment on a FWD car is a little harder to achieve seeing as how FWD usually does not allow much room for low/negative offsets. That's why I would also like to know what your stock offset is.
Return to “VIP Forum”
