ZeAl240 wrote:how much did u pay for that harness .. i need one cause mine is cut .
I've never seen one for less that $400, which is why I built my own. I got the plugs off someone who had got a Q45 igniter chip with plugs and didn't need them. If you don't have the plugs I'm guessing you don't have the igniter either, try the wrecking yards and tell them you need the ignotor and the plugs.
BuddWizErr I doubt you have those plugs if your harness was cut. The harnesses are usually cut near the back of the valve cover, the igniter chip plugs would be on the portion that was cut off.
-Martin.
